Replacement silcock access cover in shower?
Apr 19, 2020
74
Catalina 310 Kenosha, WI
On a 2001 C310, the hinge on the little access panel in the shower broke. Catalina no longer has them and I can't find it on catalina direct. Anyone know a good source for a replacement cover (with or without the entire frame)?
thanks!
4,638
Hunter 46 Point Richmond, CA
Is that your outside shower box? Need the dimensions to find a match. Found the same problem on a 1984 boat so did an internet search on "boat transom shower box" for one that closely matched the same dimensions and modified the cut-out to fit. Manufacturers to check include Scandvik, AquaTik, Valterra, ITC Manufacturers’ Select, Dura Faucet, Whale and so many others. Also look for one on Hot/Cold Marine Transom Shower | Boat Transom Shower (replacementboatparts.com) and Rv parts suppliers.
833
I put a Temptress hatch brand going from the head into the lazarette, that was one of our best investments
Nov 16, 2017
59
Catalina 310 #246 TX
This is pretty close. Probably need to measure first. They have several sizes.
