Replacement Seals for Instrument Thru-Deck Fittings?
Jul 30, 2018
62
Beneteau 321 Tawas MI
At the front of the mast on our Beneteau 321 we have 5 thru-deck fittings for various cables. Closest replacement I've found is by Seachoice, Watertight Cable Outlet for 1/4" cable. They're ~$8 each for a complete replacement, but all I want are the little seals/gasket/"o-ring". Anyone know how to source these, or have to buy the complete assembly to get the seal?
Thanks
Jun 21, 2004
2,970
Beneteau 343 Slidell, LA
I have not seen replacement rubber grommets for Shakespeare #4189 cable outlet fittings. You can remove the grommet and possibly source at a big box store or Grangers / McMasters. Another option (that I have done) is to place a bit of sealant around the base of the grommet and in the cable run and retighten. Mine has been leak free for a few years after using sealant.
595
Beneteau 351 WYC Whitby
Pickup an O-ring kit off amazon , thats what I have used for the last 12 years 2 boats no leaks 20 bucks for 100's
