Replacement Screens
963
Hunter 40.5 Bayfield, WI
Does anyone know if you can buy just the replacement screens for the opening portlights on a 1985 Hunter 34?
Mar 12, 2004
25
Hunter 33_77-83 New Port Richey, FL
Pompanette
If you have Bomar/Gray ports, you should be able to get screens thru Pompanette
Jun 7, 2004
114
Hunter 34 Weymouth, Ma
I just replaced mine
I pulled all the old plastic screen frames out. Pulled, scaped off the old screens, Purchased new screening material at hardware store. Cut the screens and super glued to the old frames. Easy and cheap thing to do..I have the same year boat so you may find some frames have crack ..Just glue them too.
