To far gone to fix it?
Hey Tattoo, first think like a sailor to see if you can repair it, glassing is not that hard. It does depend on the crack, the location and all that but a couple sheets of glass and some epoxy would be way cheaper. Than sand and paint it up. On my 85 C30 I thought the rudder was soaked with water cuz I would see some drips for awhile in the fall after hauling out for winter. I drilled a 1/4" hole in the bottom and almost nothing came out so I just glassed it back in in the spring. You may need to get into it with a grinder and file and all that, but check it out, if you think you will replace it, what have you got to loose, and ask the supplier of the new one if it is any stronger built than the old one. Anyway, I always like to try it myself first, good luck Dean www.blowinganddrifting@yahoo.com
