Replacement rubber pads under the cockpit hatches
Steve
Does anyone know where I can purchase replacement rubber pads under the cockpit seats on my 1984 Hunter 31? Mine are dried out and need to be replaced. I also need to replace the plastic hook and loop fastners on the bottom of the teak hatch over the emergency tiller.
Feb 15, 2004
735
Hunter 37.5 Balt/Annapolis/New Bern
Call Hunter
they sell them. Some folks also buy replacements at Home Depot, etc. Check the archives here there has been a lot dicussion over the years.
Dec 3, 2003
2,101
I bought some...
...from Hunter - exact replacement. I first tried Home Depot and they were a bit thin. I tried them and they deteriorated within the season. Hunter's have withstood 3 years, now. And they didn't cost too much either. But check Home Depot for the fasteners. Or else a crafts shop.
Dave Busby
Yes...I bought 100
of them for about $10 at McMaster Carr in Atlanta. Go to the link below and type in this part # 9540K16 (Recessed Bumper). They are 1/2" hight same as original, but 3/32" less in diameter, but they work just fine. Hunter wants .49 cents each for them. You can sell some to friends in the marina. Do not get the ones with a washer, it will rust.
Don Alexander
Rubber Pads
Steve, I posted this last year and it completely solved the problem. Those supplied fail with monotonous regularity. I got some rubber sheet 1/8" thick and cut pieces 1" wide x 3" long and glued them into a stack with contact adhesive. First I put a lump of Blu Tak onto the places next to the existing buffers and closed the locker lid. The compressed height of the Blu Tak showed me the required number of layers of rubber. Then I just glued it in position on the locker lands. Problem solved - forever.
Dave Winiker
Rubber Pads
Or you could buy some of those round, white rubber bumpers at your local hardware store. Got some for our H31 sliding cockpit hatch and locker lids a couple of years ago. Works for me. Cheers.
