Be careful what you choose
Hi Jon,I just went through the exercise in July and unfortunately it did not work out as well as expected. At my annual haulout I placed a brand new feathering prop on my beneteau 461. I had the shaft removed, new cutlass bearing and a check on the shaft to ensure it was straight. I got an expert to fit and check the prop. Back into the water, OH NO, bad vibration that got worse with increased revs. Phone call to the prop manufacture said the tech must have not lined up the blades as instructions, I put the tech on the phone who assured them they had. Lift the boat out again, nothing appears wrong. Decision time, old prop back on and returned the new prop. End result no vibration with old prop. Manage to get my money back on new prop, but they wanted to charge me $150 to remove anti fouling and make saleable again. With the additional haulout and mechanics fees I was already $800 out of pocket. They returned my money, but I lost $800. So unless you have a real need for an extra 1/2 knot, I wouldn't bother.Regards Mike G
