OK
On my C36 the originals are tinted, tempered glass. I had to replace one, and had an automotive glass guy in Worcester, MA, make one for me (he actually had to make it twice). It's not exactly the same tint, but its so close only I notice.I'm surprised yours are plexiglass. Are you sure? Have you tested it by tapping with a smooth metal object? Tempered glass will "clink," while plexi will "thump."The bottom line is that when I checked about 8 years ago, this part for my C36 was not available - Catalina couldn't supply the part nor identify the manufacturer for me. I highly recommend the tempered glass, but it will be a big and expensive job to replace them all that way. Plexi will be quicker and less money, but won't last nearly as long.Plexi will craze (spider cracks) because of unrelieved stress in the material, or excess solvent (as when gluing). Stress can come from cutting it. It is relieved via heat treating, i.e., stress relieving. This requires an oven with temperature/time automation. By the way, the scary part about installing the tempered glass is bending it to fit the contour of the coach roof, but it works.
