Good morning to all. Hope you are having an enjoyable and healthy summer.
I was caught in a horrific rain storm last week that dumped 2 inches per hour. I found that the port head was leaking like a sieve. The boat was built in 1980 and the original one is in place. It slides back and forth on channels and I later found that there was no material left to prevent leaking.
I would like to change it altogether. I took off the inside frame and found that the cut out is 6x15. I am not absolutely sure of the cut out radius but it might be 2 1/16th. The outide frame is brushed aluminum.
Can anyone suggest what type of port I can use for a replacement and where I can get one?. I need it to open but I am not married to a slider.
