E
Ed Childres
Has anybody replaced the mast hinge pin on their H260 with the mast up? What problems should I anticipate if I choose to do this?The lake where we have our boat docked on is 3.5 hours away from our home and isolated from any stores with a real selection. I forgot where I placed the mast pin from our last trip and the only temporary pin I could find was a 6" plain steel bolt. If I had of been able to purchase a 4" stainless bolt with nylon locking nut I would leave it alone for the season. But this toe catching sure to rust temporary has got to go on our next visit.As I remember it the mast base and cabin top plate have a keyed type relationship. The standing rigging is holding the mast in place so this connection is in compression. I am thinking that because of this compression I will need to drive the pin out. So by default if I use the "real" pin to drive out the "temporary" pin the base will continue to be connected the entire time I do this replacement. Anything wrong with this thinking?
