replacement of macerator pump
109
Catalina 30 great neck, ny
Good afternoon to all:
I discovered that the macerator pump on my boat had cracked along the housing where it meets the body. Every time the toilet was flushed, the contents of the holding tank would be pumped into the hold below the setee where it would drain into the stuffing box and ultimately to the bilge. You can imagine the mess that is created.
I ordered a new pump and the question I have is this: When I disconnect the 3/4 outlet line to install the new pump will I be flooding the boat with sea water? Anyone have any experience with this?
mortyd
Dec 11, 2004
952
Catalina 30 easy living
ln my boat the seacock is right next to the engine seacock. an unfortunate placement that led me to once close the engine seacock and almost cause an engine disaster so i painted the engine seacock da-glo orange. by the way, long ago i was taught to keep my ingition key around the engine seacock so not to neglect opening and closing it.
Aug 3, 2009
109
I have not seen a sea cock for this hose. I believe that it empties out near the transom, possibly above the water line but I will have to check it when I am at the boat. This hose is the one that dumps the effluent out.
mortyd
Dec 11, 2004
952
there is no way your boat left the factory sending waste anywhere other than the holding tank. you pump into long island sound and get caught you got heap big trouble.
mortyd
Dec 11, 2004
952
dit it leave the factory like that? is it legal anywhere in the country now?
jimg
Jun 5, 2004
175
catalina 27 dana point
Macerator
The macerator most likely empties the holding tank, and if the outlet is above the water line there will not be a seacock involved. That being the case (probably) you can remove that hose with no worry of an onrush of seawater. Find out where the other end of the hose is before you proceed any further.
Jul 8, 2011
704
Catalina 30 Sidney B.C.
Mine does the above but i do have a below the surface dishcharge that is through a door in the shower next to my toilet flush intake , also have a deck pumpout , this was all just installed in the last 2 months
Aug 3, 2009
109
Thanks for all the information. The boat is always in the waters at the east end of Long Island and there is a very good pump out system out here. This macerator gave me nothiing but trouble and the only reason for replacement is to stop the leaking when the toilet is flushed. I guess that I could have simply sealed off the tee with a plug but I did not want to play around with this. Again, thanks for the help.
