Good evening everyone:
I suspect that I will have to replace the cutlass bearing on my 1980 Catalina 30 now that it is on hard.
Has anyone out there done this by themselves? I downloaded a video that was very instructive but it appeared to be too easy. It suggested taking 1/2 threaded rod, washers and a piece of pipe and devising a tool to remove the bearing after removing the prop shaft. Is there a trick to this or is it like falling off a log? What about retattaching the shaft?
