C-22 swing keel cockpit drain thru hull
Garry, I read your excellent description on the procedures for replacing a seacock / thru hull with that ever so wonderful Catalina “volcano”.However, the particular thru hull that Aldo (and I for that matter) must content with in no way allows a “proper” thru hull.You see, on early (pre-85?) swing keel C-22’s, the cockpit drains flow down to a point amidships that is located directly on top of the end of the curved hump of a slot on the bottom that goes around the top edge of the swing keel when it is up. A nice sharp convex curve repeated in the concave on the bottom. Putting a proper thru hull here would be akin to putting a respectfully sized thru hull for a fire hydrant onto the drive shaft hump on a Crown Vic or perhaps the transmission hump on an old VW assuming the bottom plate was missing. (Of course later I will find out that Monster Garage does this.)Therefore, just about the only possible thru hull that can be successfully placed there is the famous Catalina “volcano” that holds a tube that can be threaded to accept a valve. Alternatively, in the Crown Vic example, you would weld a threaded pipe to the drive shaft hump. Thus, Catalina = volcano, Monster Garage = welding, as Catalinas are made of fiberglass and Crown Vics are made of metal.Now, as epoxy resin don’t like to stick to plastic none too well, the tube for this particular thru haul needs to be made of some substance other than plastic. Well how about metal? However, what kind of metal?Now as the thru hull here is just a pipe and not your atypical thru hull, I am sure that it is brass and not bronze, the material from which many proper thru hulls are made.Further, as I have had my C-22 moored in salt water for the past twelve years without the remotest hint of deterioration on this tube, I tend to think that it is brass as opposed to bronze which according to Garry would have long since gone to Davy Jone’s locker.Moreover, I am quite sure this tube has straight threads as the Forespar “plastic” valve that I placed onto it twelve years ago went on without a hitch and has performed faultlessly with greasing once a year. Now why Catalina placed a garden-variety bronze valve onto this brass pipe is a mystery to me. They may have figured the swing keel would be used primarily in fresh water and the original owners would not keep their C-22s long enough to experience the electrolysis problems that appear form this mating of bronze and brass. Alternatively, maybe the vale is brass or maybe the tube is bronze. However, all things point to a brass tube and bronze valve.
