Replacement microwave oven
Jun 3, 2004
42
Catalina 34MKII 1717 Merritt Island, FL
Hello, I am looking for a replacement microwave oven. The height needs to be no more than 9 3/4" high. Any one know where on is available. Thank you....Gary
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
I just measured my coffee mug, you might want to go a little bigger.
May 7, 2012
1,568
Hunter e33 Maple Bay, BC
Lots with heights at 10.2” and 10.1”. i would see if the feet could be removed to reduce it to meet your requirements. Other than this one at 17” x 12” x 9” (lwh) just keep on Googling.
RCA RMW733 0.7 Cu. Ft. Microwave (Black or White)
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
How is the opening trimmed? On our prior boat, when the trim was removed, the unit slided in. Then the trim was replaced. Also, while you have it out, think about ventilation.
Beneteau 323 Annapolis MD
An office supply place might have a "breakroom" model?
5,947
Hi Gary, what I normally do, which has worked for me many times, is to contact the original manufacturer with model/serial numbers of our non-working unit, tell them the problem details and request a recommendation for a repair/replacement. Usually, I have found them to be very helpful, may offer a special discount on a matching refurbished replacement, or steer you to an outfit that can meet your needs. I always start with a phone call to a technical support person.
Jul 23, 2009
917
I have fixed several household units by just replacing the door safety switch.
