Replacement Mast foot and deck plate or tabernacle
May 25, 2012
6
O'day 222 22 South Portland, ME
Hello forum members , I have a 1988 ODAY 222 that needs a new Mast foot and deck plate . The original set up is made from a soft alloy and has broken. Both the mast foot and deck plate or "tabernacle are in need of replacement. I can't imagine this is a first. Any Ideas or resources?
Thanks
Mike
Dec 5, 2015
119
Oday 272LE Louisville, KY
I experienced the same problem on my 1988 272. You must have the RigRite components that you cannot obtain any longer. I removed the mast foot from mine and had the bottom center protrusion ground off so that the bottom was flat. I had a hole drilled in each corner of the mast foot. I purchased a new stainless deck plate with 2 large stainless pins and had it drilled to match the holes in the mast foot and mounted it to my boat deck. The stainless steel is a bear to drill so you may want to let a machine shop line the parts up and drill the holes. I love the change on mine. I also added a deck plate where I can attach numerous blocks to the base of my mast. Rudy at D&R or Dwyer mast has the parts.
Likes: "Selah"
Jan 13, 2019
51
Lockley Newport 23 Portman Marina
Hey Mr Stanley, do you have pictures of the deck plate you added so you could add additional blocks? I'm interested as I am in the process of refitting my Lockley Newport LN 23 and looking to run everything to the cockpit as my sailing adventures will most probably be alone. Thanks,
James
Dec 5, 2015
119
James, I do not have any pictures and my mast is down and covered up for the winter but I can tell you what I used. I bought my parts from Dwyer Aluminum Mast Company. I used a stainless steel Dwyer Halyard Organizer Plate (part # DH 2150 @ $53.62) underneath a stainless steel Dwyer mast hinge (part # DH 2150 @ $87.92). I love the arrangement and I have plenty of holes to attach things and it does not break off easily like the cast aluminum from the original setup.
Likes: "Selah"
Nov 26, 2012
3
Oday 222 cooperstown, ny
Hi from Ken.. I also have a 222. Please refer to the August 18 Forum entry. This discusses various mast and mounting parameters to be mindful of in your search. Look for:
Length of mast for an Oday 222.
Likes: "Selah"
Jan 13, 2019
51
Thank you, Mr Ken. I will check it out. I'm looking for options that might make single-handed sailing for me more safe.
Jan 13, 2019
51
Thank you Mr Stanley. I will check it out as posted with Mr Ken, I want to make it as safe as possible with structural integrity for me to single-hand sail from the cockpit also as much as possible. I do have a new stainless steel mast base that we purchased back when we first got the boat on salvage back in 2006 (still in the box). As I see postings that relate to "Selah's" refit that give me things to consider when I get to that point, I then have a file to get into and ask questions of forum members. Right now, my internal encased ballast / keel and hull joinery are the focus of my attention for repair. However, the mast stepping and compression post will be close behind. Thank you for your ideas and help---everyone who is following Selah's refit .
James
