I have a 1989 Hunter 32 ft Vision and I beleive I may need to replace the main 30 amp breaker The issue I am having is the fact that my 30 amp only has one throw switch but when I open the panel it appears that there are two 30 amp breakers one of which does not have a switch protruding through the panel and one that does If I replase with a double throw I will have to drill outthe panel
if anybody out there is familar with this setup I would apprecaite any and all information
Thank you
Ed
Thank you
Ed
