replacement lenses for hatches - B361
236
Sabre 36 Express Chattanooga, TN
I have a 2002 Beneteau 361. The lenses for both of the large Lewmar hatches (forward) are "crazed." Also, the latches and hinge plates on top are very weathered as well. I have sent several emails to "Hatchmasters" (Select Plastics LLC in Connecticut) and can't get a response. I had heard that replacement lenses were available from Lewmar and that they could be user-installed. I'd like to get them replaced this winter. Anyone have any experience with this problem?
Thanks,
Agaliha
Rick I
Jan 6, 2007
414
CS36Merlin and Beneteau 393 - Toronto
Lewmar has them
Lewmar has them but unfortunately they have so many different ones you have to give them the part number. Even Beneteau doesn't know which types they put on the boats. The number is stamped on the lens, near the edge Sometimes it's hard to see as it might be covered by the gasket. I got replacements from Lewmar and installing them is fairly easy.
Sep 24, 2006
236
Lewmar contact
Great! Thanks for the tip. How did you contact Lewmar?
Agaliha
