Replacement Fuel FIlter on my H33
254
Hunter MH 37 Manitowoc, WI
OK, so I'm shopping for a replacement fuel filter for Patronus, my 2011 H33. The existing fuel filter element is a RACOR R12SUL. In my internet search, I found both R12SUL and R12S filters. Spec wise, they both fit the filter assembly and are 2 micron, except one appears to be UL listed. The R12S is about 1/2 the price of the R12SUL. Defender only lists the R12S. West Marine only carries the R12SUL. What are you guys using?
15,184
Not too sure about your question regarding the price difference, but I think you will find that they recommend a 10 micron on the racor (not 2 micron). Your filter on the engine is the secondary and I think that it is less than 10 microns.
From the Parker/Racor filter website
R12SUL: Used In Model 120RMAM Filter Assembly
R12S: Used In Model 120A Filter Assembly
What housing do you have?
May 10, 2008
392
Catalina 355 Boston
The UL designation is for use with the metal bowl. Is your inspection bowl (the one on the bottom of the filter) metal? The good news is either UL and non-UL filters will fit. I also agree with Steve that you may want to consider a 10 micron filter since your secondary filter is presumably a 2 micron--the micron size is your choice though.
May 10, 2004
254
We have the metal bowl and our filter is in the engine compartment. The original filter is a 2 micron, so I,ll probably stick with the original spec filter.
Dec 2, 1999
15,184
Juice:
I think if you would check with a Yanmar dealer they would NOT suggest a 2 micron primary. I know you say that it was the original, but it is not a Yanmar recommendation.
It's your boat, it's your decision.
May 10, 2004
254
Thanks for all the help
Well, I've gone an ordered the 10 micron filters. I did note that they did not have a UL listed 10 micron filter. I wonder if the factory put the 2 micron filter in for the UL rating or possibly to clean up any debris from new construction.
I did order two so that I have a spare.
Thanks again for the advice.
