Hi Guys
The original cutless bearing housing on my boat has been cut off flush with the back of the keel. As I'm reconverting from outboard to inboard, I need to both extract the remains of the old housing and source a replacement. Ideally, I'd like something the same as the original spec that I can grab reasonably locally but I guess anything that can be made to do the job will suffice.
One issue I have is that I have never seen another Vega in the flesh, so aside from some photos on the web, I have no idea of either the external dimensions (i.e. the bit protruding past the end of the keel) of the original housing or how it was fixed into place.
So, my questions for today are
What are the best / least destructive / least heartache producing methods for removing the remains of the old housing and;
Does anyone know of a commercially available housing and bearing that can be used as a replacement that will result in the least destruction / least heartache in the process?
Oh, and while I'm at it, the engine side of stern tube that pokes out of the hull has some minor damage at the very end. I'm thinking of cutting away about 10 to 15 mm with a Dremel tool rather then try to repair it. I intend to fit the Volvo Black Jack stern seal. I don't think that this will cause any problems, but if anyone knows otherwise I would be glad to hear it.
Thanks again!
Thanks again!
