Danforth or Fortress
Both types hold well in mud and sand, are easy to stow and are relatively inexpensive. In addition, the H26 is not a heavy boat.The trees pose two problems; how do you know that the anchor is really set in the bottom and not hooked over a tree branch (and possibly let go during the night if the wind shifts) and what happens if the anchor snags in a branch and you can't retrieve it next morning? A trip line and an anchor buoy should solve that problem.If you don't want the hassle of a trip line, you can also try securing the chain to the head of the anchor, leading it back along the shank and tying it to the stock with light line. As long as the pull on the rode is in line with the stock, the light line will hold and the anchor behaves normally. However, if the anchor gets stuck, pull the boat up to it hand over hand until you are directly over the anchor, then pull hard. The vertical pull should break the light line and you can pull the anchor out by the head. Try it one afternoon in a clear area and see how it works. Good luck.PeterH23 "Raven"
