Thanks, Donalex. It all makes sense.
The bank is more like in the 400-amp size (gel), so 100 amps alt. should not be a problem.
Not sure what you mean by: "...it all depends upon the sophistication of your charger and whether it can sense the battery's needs and control this level of current" since the alternator charges the batteries without the help of a charger. Please clarify.
Do you know where I can find the postings of Mainsail and Stu Jackson on this topic?
Hi,
Nowadays mains powered chargers do their work in several stages to suit the 'Bulk', Absorption', 'Float' and 'Equalize' requirements of different types of battery construction. To achieve this the charger designers assume the charger is left on during the whole of the charging cycle.
Alternators DO need controllers or regulators (I used 'charger' by mistake, though it does the same job - apologies) because they otherwise would never achieve 100% charge without danger of severe overcharging. The problem is that the engine is unlikely to be run continuously for the duration of the charge. Many 'smart' alternator controllers make an attempt at emulating the various phases necessary but the vital part is they must not overcharge; so this normally leads to undercharging.
Simply buying a new alternator does not gain the benefits of a decent charge controller. They are rated for the maximum capacity of the alternator so, if you have one, make sure it can handle 100 amps. Indeed, if your boat does not have one of these already then the biggest improvement to your battery charging might be to buy one.
High rate mains chargers usually include battery temperature monitoring and adjust their charge rates accordingly. With a 100 amp capability one really needs this temperature monitoring on the alternator's regulator also.
This, together with the previous paragraph, was behind my remark about the sophistication of your charger etc.
Like I said it is a big subject - and it has been worked over endlessly on this site over the years.
To locate contributions from the two Gents mentioned use the search facility on this site using either their user names or by using 'battery' as a search keyword. You will get hours of happy reading. Also look for Stu on the Catalina Owners site.
These guys have made it a lifetime's study; and - most importantly - no crap or bullshit.
