Need help in trying to fix my 393 prop shaft raw water lube fitting. This is the fitting that leads into the sleeve and runs from the through hole to lube the shaft. The fitting broke off and needs to be replaced. Is it threaded into the fiberglass or is there a female fitting epoxied on under the glass? Can’t seem th find any details?
TX
TX
