replaced start button, now oil light on and
19
Catalina 30mkIII austin
Hope some one has an idea. my start button went bad and i replaced it ,then i started the
motor and the oil pressure light stays on ,also when in lift the kill handle the buzzer
warning the key is on does not buzz. is there a connection between the light buzzer and the start button?? or does my iol pressure have a problem and buzzer went bad all at once after
changing start button..
Thanks for any ideas it is a catalina 30 1996 ..
is there an easy way to ck oil pump...
Steve
May 17, 2012
21
Catalina C400 Corner Brook
Hi
My guess is that there are more then 2 wires on the switch and now you have the one for the op light on the wrong side of the switch.
