Just got around to doing this over the weekend. Very easy to do. Peal back the rubber gasket from the bottom of the GPS unit, unscrew 6 small phillips head screws, use a small flat screwdriver in the slots to unlatch the plastic clips and seperate the base from the cover. The battery is right there in front of you. It simply slides out of the holder no soldering required. Took all of about 20 minutes and cost $4.00 for the battery as opposed to ~ $400 for the new GPS antenna and seatalk conversion kit. The unit now gets a fix almost instantly on powering up.
