replaced wall carpet!
I bought a beat up 1994 Hunter 26. I used a heat gun to remove the old stuff. It did not come off easily. I replaced it with a tan vinyl (matching the tan headliner) with a slight texture print and backed it with some thin foam. I sprayed 3M upholstry glue and applied the foam then repeated with the vinyl. This is a two person job. I added a 1 inch teak trim piece fore and aft between the bottom of the headliner and the top of the vinyl. Got the cushions done in a tweed fabric, made smaller teak ply table the exact same shape as the original, made a ply forward berth extension peice that stores under the forward cushions and rests on the smaller table, took down the foreward curtian, and installed a curtain just behind the companionway steps. Looks great and gives the boat a badly needed reduction in a "plastic" look with the teak trim added.
