There is an article in this months BoatUS trailering mag that hints at trailer tires should be replaced every 5 years – regardless.
And, a friend of mine that is a RV person has told me that I’m nuts for still using the tires that came on my trailer from 1998.
This is a Hunter 26 trailer with dual axils and is between 6,000 and 7,000 lbs when pulled. (the axils are 3,500 lbs each, and I believe the tires are rated 1,750 each – so at or near max capacity).
Any experience in this area?
I should state the tires show no defects and the trailer is stored in a forested area where it rains more than the sun shines.
Thanks in advance.
Thanks in advance.
