Replace the sheave on a block
Jun 5, 2013
76
Hunter 23 St petersburg
How do I replace the sheave on a block. Mine are small sheafer block and appear to have a rivet axis. How would i go about replacing the axis.
For the cost of a small block it is probably faster and easier to replace the block with new.
For larger more expensive blocks Schaeffer will rehab them for a fee.
Nov 6, 2006
10,149
Drill the smashed part of the rivet axle then drive it out using a support that can let the axle push out.. Replace the axle with a stainless bolt and nut.. The bolt should not stick out past the nut.. Carefully done, you'll have a great result.
Hunter 34 Alameda CA
What Kloudie1 said. I used that method on my Lewmar Cheek blocks. The replacement axle was a clevis pin. Since the block mounts to a flat surface the pin won't fall out. Easy to service the next time.
Likes: kloudie1
Jun 5, 2013
76
Thank you all; yes i was not sure what to replace de “axel” with. But the consensus is to use ss bolt. Simple! I like it.
I did not want to replace because i still have not found the replacents and i do not want to replace fir different ones having to seal and reopen holes in the deck.
May 24, 2004
7,202
CC 30 South Florida
Blow the rivet, find the proper size sheave and use a bolt and 2 nuts(counter tighten) to secure.
capta
Jun 4, 2009
5,006
A lot easier and simpler to use the nylon lock nuts. Then you don't over tighten it.
