Replace Stays on a Beneteau 343
Jun 20, 2021
165
Beneteau 343 Fort Lauderdale
Any leads for me? I would think there would be a cable kit to replace.
Also, what's the procedure? I'm on the hard, so do I rent a cherry picker?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Likes: sunlover
Jun 21, 2004
3,214
Beneteau 343 Slidell, LA
Try Beneteau spare parts. My understanding is that the part number is #458057 (not 100% sure, need to verify). You could also contact US Spars, they supplied the mast & associated rigging. You can use a cherry picker & let the yard replace the rigging with the mast standing (probably more expensive) or have the yard remove the mast & you can replace the rigging on ground, then have the yard lift mast while you reinstall clevis pins to chainplates. Please give us an update with regards to your findings.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
If your mast is Z spar US Spars, contact them, They should have all of the dimensions for the original standing rigging.
Running rigging specs are in the owners manual.
I would recommend taking the mast down and replacing everything while on the ground. Much safer that way. Check everything attached to the mast while its down.
Your jib furler has to come down to replace the forestay, and because of the connecters between the furler sections, depending on brand you will not be able to remove the forestay without cutting off the stem fitting, and when you pull it out, tie a messenger line to the end so that you can thread the new forestay through before installing the new fitting.
Joe
Jun 1, 2004
8,339
You need to do some research and learn, learn, learn. Lots of stuff on You Tube to get you started. Get a quote from the yard or an independent rigger...or call a rigging service .... local or online... to get estimates... they will help you through the process, At some point you may have learned enough to tackle the job yourself... that's what I did.. and it was an important milestone. You'll know if you're up to it... and you'll be motivated when you realize how much money you can save with a DIY project. Good Luck.
Jun 20, 2021
165
Yep, yep. I was using the wrong keywords as instead of 'stay' or 'shroud', I should have been searching on 'standing rigging'. Thanks everyone for the jump start.
