H28.5 Gland
If you have the OEM white nylon packing gland, as I do, it may be adjusted (tightened) by removing the locking cotter pin and turning the large nut nearest the coupling a bit clockwise and then replacing the cotter pin to lock the nut. If you are able to tighten it, that may reduce the leak to an acceptable level and fix your problem. If your original packing material, however (could it really be 15 yrs old???) is in need of replacement, that is a job best done with the boat on the hard. Once you remove the lock nut from the gland, you'll find a compression washer pressed against the packing material, and this must be removed. Some have done this by cutting it with a small Exacto knife and prying it out; others have loosened the hose clamps on the rubber gland and slid the whole unit forward, then back, thus exposing the washer. Yet others have gotten the washer out using picks. At that point, some sort of pick or corkscrew can be used to remove the old packing material and it must be removed. The OEM gland will take 1/4 inch packing material, either flax or teflon impregnated. I plan to do this job on my boat when it is hauled in a few months. If getting the washer and the old material out proves difficult, I'm going to replace the whole unit with a conventional bronze gland -- which will make repacking the gland in the future much easier.
