Replace Maxwell 500 windlass circuit breaker
Sep 17, 2023
8
Catalina 310 Oriental, NC
The Klixon circuit breaker on my windlass has failed. Am having a hard time finding the original part (TI Klixon 6766-19-80 9939, see photos). Does anyone know of any other model that will work as a replacement? Thanks, Roger
7,370
I would say to look at the Maxwell 500 specs and see what is required in the way of maximum amperage.
Amps = 600W / 12V = 50A.
See the Maxwell Install manual :
..................... as it's too large to post here.
A 60A breaker would be sufficient. Go with a reliable mfg. like Blue Sea.
DaveJ
Apr 2, 2013
508
Is there an amperage rating on the breaker?
Also, look at the wire size to ensure that the new breaker is sized correctly. If #6 wire, then a 60A breaker is acceptable.
Cheers
DaveJ
Apr 2, 2013
508
I don’t think you’re confused.
:stir: Maybe….
#8 yes, #4 no.
Replace with same size breaker.
At this point, we don’t know existing breaker or wire size.
Jan 4, 2006
7,370
:stir: Maybe….
#8 yes, #4 no.
Why would you need a different breaker if the wire is #8 ?
In order to get this project on the rails and moving, I gave the OP a copy of the installation manual for the Maxwell 500 which told us the windlass pulls 50A maximum. That was pretty well the end of the story. Deal with a 50A draw. We don't really care what the amperage of the failed breaker was given that info. Don't make it any smaller or you've got nuisance trips. Don't make it too much bigger or you may be endangering the original wiring. My recommendation was 60A. That would have enabled some not too bright individual to safely put in 10AWG wire and the windlass would have barely turned over if at all. BUT everybody's safe.
You're right, we should have ensured the wire was sufficient for 60A but the correct breaker for the Maxwell 500 is a 60A breaker by my calculations.
Mind you, you could go to the Maxwell breaker sizing chart for the 500VC :
........................... and then explain it to me :laugh: .
Sep 17, 2023
8
The old one was a Klixon 80. Replaced the entire unit with a new one from Catalina Direct. Works great. Too bad they couldn't match the old mounting screw pattern, but, oh, well.
Jan 4, 2006
7,370
Am I correct in assuming the new E9 80 is an 80A breaker ?
Were you able to determine the size of your wiring to the windlass and does the new breaker have the correct amperage rating ?
Nov 15, 2023
13
Catalina 310 242 New Orleans
Take care when reading the Catalina Direct page about their breaker. They say it's 135Amp, but the original one on my 2003 boat is a Klixon 6766-19-80 9157, which is 80 amp. I don't think the winch draws more than 50 amps and I don't think you can run 135 amps on a #4 wire.
I replaced mine with a Blue Sea 7042 187 - Series Thermal Circuit Breaker - 80Amp https://www.amazon.com/dp/B08C23Y3MZ?psc=1&ref=ppx_yo2ov_dt_b_product_details
I replaced mine with a Blue Sea 7042 187 - Series Thermal Circuit Breaker - 80Amp Amazon.com
Be careful ordering Blue Sea products on Amazon they are often fakes.
Nov 15, 2023
13
Scary. The one I received seems to be very high quality, though.
It is not just Blue Seas. I ordered "Genuine Cannon Ink" for my printer, received some knock off brand. Sent it back. Occasionally I shop at Amazon, but only for things where quality or safety is not a big issue.
May 7, 2011
227
Catalina 36 1430 Lake Lanier
I'm confused.
If the existing wire was a #4 wire, would it require a different breaker ? Or, if the existing wire was a #8 wire, would it require a different breaker ? At what point would a 60A breaker no longer be acceptable ?
Breakers/Fuses protect the cable. A 60A breaker is no longer acceptable when 60A is beyond the cable's ampacity. You can always but in a lower rated breaker/fuse than what the cable can handle, but never a higher rated one.
Cable ampacity is affected by voltage, distance, heat, composition, etc. That is why you look it up on charts. Make sure you are using tinned copper marine grade multi-strand wire and use the appropriate chart for the cable type being used.
Likes: DaveJ
