Replace Lifeline Stanchion, '81, H30
Jeff Dunham
The reinforcing elbow on one of the life line stanchions has sheared off ( I really must have hit the piling hard!)and I need to replace the base and stanchion. The base fastens to the toe rail, makes a 90 degree bend and then fastens through the deck. I checked the normal catalogues, but could not see this type of base/stantion combo. Has anyone run across a new version or do I need to head up the Bay for the next boaters' yard sale? Thanks and good sailing.
Paul Akers
Check with Hunter
They stock some stanchions or can manufacture them in their shop. Also, if it can be welded, check out local welding shops that may be able to repair it.
