My Jabsco 37202-0000 bilge pump, which may be the original on our '99 Beneteau 321 (ours just a year) makes a LOT of noise, but still pumps the bilge OK. I plan to replace it shortly, both to reduce noise and avoid its failure which I think its noisiness predicts. Plus, it's rated at only 4.5 gpm, which is obviously too little were we to have a real problem. I have some, but not a ton of space to work with; it's currently mounted under a settee with the fresh water pump and water heater, that is, not in the bilge, not submerged (see attached).
Does anyone have any suggestions on a make/model for this application? I'm willing to spend several hundred to make sure I've got a very reliable pump.
