Replace interior cushions
14
O'Day 272LE Satellite Beach
Zippers deteriorated, fabric/foam have diesel smell. Looking to replace. What is the best foam and fabric material to use? Any companies in Florida? Thanks
May 31, 2004
858
Catalina 28 Branford
Get ready for some sticker shock my friend: replacing the cushions with new custom-made ones is ridiculously expensive. However, that's not what you asked.
Used any good closed cell foam, like a polystyrene. Closed cell foams are much more resistant to the absorption of moisture, so they will be less likely to get mildew and hold a funk. As for fabrics, you can go with Sunbrella, but if these are interior cushions, that seems a bit of overkill to me. Any good grade synthetic fabric will do the trick. I would pick a pattern that is on the light side (to avoid making the cabin seem dark), but with a pattern that will hide dirt and stains.
You should also consider having the bottom side of the cushions covered with something other than the top side fabric. I have seen it done with something like a solid vinyl, and with a mesh fabric. Two completely opposite approaches, both with their pluses and minuses.
One other practical tip: when I was looking for quotes to replace the cushions in my boat, I found the marine specialty shops to be universally higher-priced than my friendly neighborhood upholsterer. By at least 10%, and in one case, almost 30%. Btw, the cheapest quote I got to replace the seven interior cushions in my Oday 23 was over $2000. In fact, one of the marine shops who quoted me a price of about $2200 said that he knew it was a lot of money relative to the value of the boat, but that he only pretty much broke even on these small boat jobs. This was 10 years ago, and I can't believe it would be cheaper now.
Now you know why you always see those "make your own cushions" articles in the sailing mags.
Aug 20, 2010
1,399
Oday 27 Oak Orchard
See also "And so it begins," page 7 for some DIY on a complete cushion redo. The material was purchased from www.decorativefabricsdirect.com at ridiculously low prices. The bottoms are Outdura but Sunbrella can be used if that's your choice. I had zero talent in the sewing dept but it isn't all that difficult. The original cushions on my 22 had Naugahyde bottoms and Olefin (Herculon) fabric.
