Peggy doesn't know
that we have an adage here in North Carolina that goes, "those that think they know it all only annoy those of us that do. In the first place, I said 9 gallons and not six. This is adequate, but admitedly not ideal. Idealy, I would prefer more capacity in my holding, fresh water and fuel tanks. However, if I really wanted more I'd buy a larger boat. Otherwise, I have jerry cans for fuel and water. We plan our cruises to use the pump out facilities at marinas along the way unless we do go offshore. In addition, I suggested a fitting to allow the introduction of treatment chemicals. I had in mind the type that lessens the environmental impact of dumping a holding tank. Second, check the chart and you will see that the Atlantic Ocean is outside the barrier islands (OBX). My boat is berthed fifty miles from the nearest outlet which is at Ocracoke Island. That's quite a ways to go just for a dump. Thankfully, the marina where my Hunter 30 is berthed provides free pumpout. This is added incentive not to dump your tank inland.Our inland waters and salt marshes are the nurseries for the ocean. Recreational and commercial vessel operators watch these waters and strive to protect them. Further, The waters of eastern North Carolina are inland coastal. Although they are not designated as "No Discharge Zones", the estuaries and sounds are protected under North Carolina General Statute 79. So, don't plan to dump your holding tank here. There is a $500 or higher fine. Fortunately, many marinas here are upgrading and adding dump stations thanks to federal money specified for that purpose.Finally, Mike of Sanduskys question is related to replacing a bladder with a fiberglass tank. Since I own a H30 Cherubini also, I offered a suggestion based upon the refit I made. The adaptation was made according to my preferences and the space available. Simply, as most sailors know, you do the best you can with what space you have.
