Replace floor panel; 1990 Hunter 28
Dean Sandmire
The 3/4 teak plywood floor panel under the companion way has delaminated -- water damage from hatch. Any ideas about how to replace it? If Hunter Corp still stocks, would the price be prohibative? Is there a source for teak plywood panel (inlay) approx. 26"X 39"?
L
Lyn
New Floor Boards
I just replaced the floor boards in my 27'. I went to a specialty wood shop that deals with custom building products.You will not find what you need at HomeDepot type stores. I bought a 4'x8' sheet of 3/4 plywood with a teak and holly overlay on it. It cost about $200 and matched the original perfectly. I cut and refinished them myself and they look beautiful!!!!!!!The source is in Massachusetts. I'd be glad to email you the name and number.
Dec 2, 1999
15,184
Hunter is usually cheaper.
Dean: Hunter is usually cheaper but then you need to consider freight. If you can measure the the teak
F
Frank
I purchased my floor from Hunter.
Hunter provided a quality floor ujnit and excellent serivce. I found that it was easy to install if you first cut the floor board length wise.
