I was out in rough weather last week and the jib halyard broke and dropped into the mast on my 1985 Hunter 34. I have tried running an electrician's wire up the mast with which to pull down,or up, a new line. Getting the wire into and started up the mast was difficult and frustrating. There must be some trick to this. I cannot visualize the path the rope & wire must follow around the sheaves and up the mast. And when and if I can get the wire to the top or bottom of the mast, how do I pull it out. A 90 degree turn seems essential. Any help here?. On one try I got the wire a third of the way up when it hit a wall and would go no further. Anyone else have this problem. If so how did you resolve it? How do you install new halyards through the mast when the old halyard is not there to tie to. I can go up the mast with a mast mate and drop the wire from the top but would the problems not be the same? Anyone have a diagram of the route around the sheaves and into the mast? Thanks. Norm
