Bob
I have a Hunter 285 (1987) and I've had the rudder pulled for repair. The bottom paint has all been sanded off and I've removed the outer skin from about five areas (on either side of the rudder) where there was extensive delamination. I only cut into the rudder about 1/8" at the most just to remove the top layer which is the first layer of fiberglass and the gel coat. Right now the rudder is "warming" itself over a heater the force the water out of the fiberglass which is damp but looks to be in good shape. There are a few points where the water was actually dripping out for a few minutes.After (and I'm guessing here) about a month or so over the heater, and when the rudder is again dry, I'm planning on gluing the skins back in place using Interlux Epiglass Epoxy. Then filling in holes and fairing with Interlux Watertite Epoxy Filler. After that it a barrior coat and finally a light colored bottom paint.I got the product recommendations from the Interlux guy at the Atlantic City boat show this weekend. I'm sure that there are other companies that make the same sort of stuff for what I'm doing. My question is, does this procedure sound right? I've never done this before. I did have a guy from the Boat US store in Cherry Hill, NJ tell me to forget it all and have my yard do the repairs because it's just too hard and I'd screw it up like he did once. Little late for that since I firgure I'm about half way through the process. Beside if they sell the stuff to fix it then why say you can't do it?!
