Repair Damage
75
Catalina 28 Cedar Rapids, Iowa
Hello all This question was prompted by some discussion on a eariler thread. I have a H26 that has a couple bits of damage. One is where the bow roller had chiped off the gelcoat in a few places. There is an area of about a 1/2 inch square that needs to be fixed. Second last fall when visiting a lake near a friends house we pulled in an over night slip and snagged a dock tie down cable that had broken from it tie down and gotten wrapped around a piling. The left a few small gouges in the leading edge of the rudder. What would be the best way to go about fixing these. Thanks Jason
Jun 7, 2004
39
- - Long Island NY
Damage Repair
Jason, There are several ways to attack this repair. The basic idea is to re-seal the rudder since it's foam. As follows: 1) Let the rudder dry for awhile since there surely must have been water intrusion. 2) Use either Marine-Tex or epoxy to cover/seal the area. (I personally like Marine Tex: easy to use and I'm comferatable with the cure rate. 3) Fair the area smooth 4) Put antifouling paint or a barrier paint coat. Good Luck, /Chuck S/V Windsongs H23
