Hi all,Im currently renovating a MacGregor 25 from 1985. I had hoped to use it this summer but the work needed is much more than anticipated. Anyway i could do with some advice on the following:1) The next step is to renovate the rusty keel (see http://jonwri.blogspot.com/ ). Im booked a metal work company to sandblast it and then cover it with epoxy.This is the right thing to do isnt it?2) When i get the keel back i need to get a new steel bolt to hold it in place since the other one is bent from the weight and has some signs of corrosion. When i put it back does anyone know if the main keel bolt is above or below the waterline? It looks to be close but im not sure. I hope the designer thought about it and put it above! The reason im asking is because i may have to renew the seals etc as well and want to know just how waterproof it needs to be. If its above the water line then it doesnt matter quite as much.3) As you can see in one of the photos on the weblink i painted the inside light blue. Unfortunately i just used normal paint which is now pealing off the fibreglass / epoxy. Has anyone also painted the inside of the boat and found a good paint? 4) There are some scratches on the outside of the hull and on the seating area. Some upto 5mm deep. What should i use to patch them up?Any suggestions and comments most welcome... just hope all this work is worth it!!Jon.
