You need to Google or Bing(?) for Renault info. The last that I remember about parts and manuals is that the place was somewhere in Texas. Maybe someone will remember where.
Hey David, there isn't much to do for the little one lung beast. Obviously change the oil on the engine and transmission (reversing gear as the manual calls it). A new impeller occasionally, new fuel filter, valve clearances need to be checked (manual has the procedure - it's very simple), and check and adjust (if necessary) transmission linkage. Oh yeah, make sure all hoses are in good shape and the belt is not worn or loose.
