Both comments are right on,,,,, If the yard you are in has a boom truck or a high reach fork lift it's work the $100 or so they will probably charge to lift the motor out and it will take only a few minutes if you've done the prep work. . On my Yanmar there is a lifting ring attached to one of the bolts on the head. If you do not have a lifting ring on your motor see if you can make one out of a piece of metal with 2 holes in it bent like a L. One hole is for a bolt on the top of the motor and the other is to put ahook through. On my boat I slid the motor forward a little as noted above and then used a comealong (a winch and cable set up they use for putting up chain link fences- you can get one at home depot for about $30).Put a few 2x4's across the top of the hatchway and winch the motor up. If you have a few strong guys you can lift the motor out of the cabin with 2 guys on each side of the 2x4 and put the motor on the cockpit floor. The next problem is how to get the motor out of the cockpit. This is harder and depends how your boat is stored. The lift truck form the yard is the best bet however.....Good luck.
