renault 8d alternator relacement
76
Hunter 27 beacon ny
has anyone found a genaric replacement alternator for renault d8? one from the UK is about is around.. 400us shipped. there has got to be an of the shelf small car alt. that can be fitted without much fuss...cheers frank
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
Hey Frank,
What's up with your alternator? Maybe some of the alternator gurus here can offer some advice. That being said, it's possible it can be rebuilt at a good shop for a lot less money, otherwise you should be able to drop in one from another manufacturer like Balmar. It can't be too high amp though, you'll use most of the engine's hp to drive it!
I'm sure your aware but on the Renault control panel there is a switch to "turn off" the charging, if you are finding that the alternator isn't charging it may be that switch or wiring. I've noticed on mine if I switch it back and forth a few times while giving the engine some revs the alternator will kick on.
Manny
Apr 15, 2009
76
Hunter 27 beacon ny
Hi Manny, my wiring has been tinkered with a bit so alt. cut out by passes through switch with amp meter. rpm drops upon actavating switch as though load produced but I get only 12.45 volts at alt. terminals.
