Removing waste take sender
10
Beneteau 423 Toronto
My waste tankk sender is cemented in with 5200. It will not come with gentle screw driver prying. Any suggestions?
Thanks,
Geoff
May 28, 2009
764
Hunter 376 Pensacola, FL
Pretty sure they make a solvent that dissolves 5200. Check online, or I'm sure someone here knows what it's called. Heat can also work to soften to soften 5200, if you can safely use a heat gun in the area.
