Removing vinyl stripes
343
Hunter 25.5 Carlyle, IL
What's the best way to remove the vinyl stripes / decals on a 25.5? Is there some kind of solvent that could be used to help soften them for removal?
C
Clayton
Try and eraser
Try looking in the forum archives for something called an eraser. From what I have heard, it is a wheel of eraser material that you chuck in a drill. Supposed to work very well. Good luck, Clayton s/v Walkabout Hunter 26.5
O
Okiman
Heat Gun
Use a heat gun - I have successfully used a heat gun to warm up the vinyl lettering and carefully using a single edged razor blade, lift the lettering off. Using any type of chemical to melt them off makes a big mess and you could end up staining your gel coat. Good luck.
- - Lake Travis
Heat Gun
We recently replaced our stipes and used the heat gun. Worked extremely well, very easy. Just warm up the tape and start pulling.
