robin
Removed the old lettering with an iron over towel, then peeled off the vinyl (very easy to remove once heated). Guy at the lettering place said there may be some "shadow" behind the letters. I tried a bunch of chemicals, rubbing compounds, even lightly sanded the area but nothing takes off this shadow. Any suggestions? How can I match the paint? did hunter use a standard color over the gellcoat or is this gellcoat that i need to gell coat over? Also have some deck spots that are fading so i dont mind painting.
