Can anyone recommend a solution to clean two stroke exhaust marks from the back of the hull? My old inboard is two cycle
Could this be a replacement for wet sanding??Removes surface gel coat
The finest wet sanding paper I use when chasing spider cracking is #3000 grit. Meguiar's #44 would be the equivalent of about #one zillion grit. The description says it only goes after oxidized gel coat so that gives you an idea of how mild it is.Could this be a replacement for wet sanding??
Ah yes, silicone. Another old wive's tale perpetuated by sailboat web sites.As for SOME of the Meguire's products, they might contain silicone.
How long will this stuff hold up?Ah yes, silicone. Another old wive's tale perpetuated by sailboat web sites.
Yes, silicone will cause adhesion problems with new gel coat, paints, etc. However, a quick wipe with #600 wet/dry emery paper ensures that any contaminated gel coat is quickly removed. Even if you plan to paint your exterior, silicone would be the last thing on my mind as you will be sanding the gel coat before painting.
