Removing the control tube from the prop....
Oct 30, 2019
114
Whilst removing the combi I forgot to loosen the nut at the back of the prop as per Steve's instruction sheet - I have already given myself a sound thrashing (don't enjoy it as much as I used to!)
I believe it is screwed into the prop boss (normal right hand thread?) so I assume I just need to unscrew it. It seems very tight - any ideas how to grip the control tube without damaging it? Or am I doing something stupid (again)!
Thanks again.
John
ps I have read here that the prop is not electrically connected to the engine so it needs a zinc - where on earth do people fit them?
Sep 24, 2008
346
A propeller needs zinc protection because it is in an electrolyte (salt
water) in the presence of other metal objects that are more noble (drive
shaft normally but also rudder shaft. Most propellers are made of manganese
bronze which has up to 39% zinc. If you do not have a sacrificial zinc the
least noble (anodic) metal becomes the propeller and that gets expensive.
Whether the prop is connected to the engine electrically or not this will
occur as 2 different metals in close proximity in salt water creates a
battery, with a small current flow from one to the other.
Oct 30, 2019
574
I bought the zincs I needed from the company at the link below. The link should take you right to the correct page. If not, let me know and I'll post additional information. They were very helpful and responsive to emails.
Jack
Bella - V2620
Oct 30, 2011
221
Hi Jack.... there does not seem to be a link? If you can give me the
details I would be very grateful. Thanks...
Oct 30, 2019
574
My apologies. My half-heimers is making me forget half of everything. I forgot
the link.
Here is the link to what should be the zinc:
Oct 30, 2011
221
Whilst ordering the anode shown in Jack's link I noticed an engine
anode - it says its for the MD6... where on earth does that go? It
is attached to a threaded nut so I guess it screws in somewhere?
n4lbl
Oct 7, 2008
307
I just rechecked my MD6A *Instruction Book* and *Workshop Manual* (such as
it is) and could find no reference to an anode.
I hope I missed it.
Alan
Oct 31, 2019
230
Hi gang - curious to know how much do those special Vega zincs cost once
you convert to pounds or US dollars?
Trevor (V2915)
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On
Behalf Of n4lbl
Sent: March-02-12 6:27 PM
To: AlbinVega@yahoogroups.com
Subject: Re: [AlbinVega] Re: Removing the control tube from the prop....
as
I hope I missed it.
Alan
On Fri, Mar 2, 2012 at 2:24 AM, johndenney johndenney1@...
mailto:johndenney1%40gmail.com wrote:
Oct 30, 2011
221
I think they are about ?20... they seem to be designed to fit on the
rear of the prop held on by the existing bolt.
Oct 30, 2011
221
I have had a good look all over the engine and I cannot find anything similar to an anode either... weird. The catalogue clearly shows one for the MD6... is it an important bit?
Oct 30, 2019
574
They are about 30 USD. I might consider another option, but this one fits perfectly at the aft end of the prop boss. I remove it once a year to grease and inspect the prop.
Jack
Bella-V2620
