One more question! I'm trying to remove a damaged pullpit to have it repaired. The biggest hang up is accessing the two bolts furthest ahead on the piece. They are directly behind the anchor roller with no direct access. I was considering cutting off the piece at its base and having the metal shop add a plate at the bottom as a possible solution. Or, if someone knows an easier way to get this thing off... I'd appreciate the advice.
