mike
I've spend hours trying to get the salon table off my F235. it requires the removal of the compression post that transfers the load of the mast to the keel, but how is it done?Does eny body have an exploded diagram of the sampson post? or have you ever removed it? the factory says it's a nested combination of two tubes.Beneteau implies i can do it with the mast stepped - if i am careful and don't leave it like that. i planned on removing the post, slipping the table of and putting the post back. with the 4 lower lag screws out, and the locknuts off the underside of the mast step removed (3/8 of the bolt ends showing) i cannot budge a thing.
