I did this with electricity, I would not think of trying without, maybe rent a little generator, and try a magic eraser, get them from a body shop, heat gun works too, I did both and I would use the eraser if I did it again, it hooks up to an electric drill, ihave a 31' it took two of them
Try a butane/propane torch with the paint remover nozzle. Be extraordinarily careful. You'd probably get enough heat holding it about 18" away. Also if you have DC but no AC they do make 12 volt hair dryers.Jimh37.5 "Esmeral"
