Paul
Hi,I have a knot meter sensor with the small spinner wheel on it. It is mounted in a thru hull. The boat came with a factory plug for the fitting.I would like to remove the sensor and clean but I am a little reluctant to unscrew it while in the water. I have a Catalina 30. Is it OK to unscrew this while in the water???? How much water actually comes thru the hole while I am fumbling to get the plug screwed in???Thanks,Paul
